Hello everyone!
I'm trying to design a high power h-bridge.
The DC voltage is 200V and the motor is rated for 20A.
This is a servo motor (brushed) with an encoder.
I have written a program for the MCU that uses the encoder and PID for position control.
Now i need to design a proper H-bridge.
I have some 150A 1200V brick IGBTs and IR21844 drivers. I made some tests with only the drivers connected to the gates of the bricks and scopes seem fine.. I don't want to blow up the bricks so I was thinking if the IR21844 are the right drivers. They hava only one input for driving the HIGH side and LOW side IGBT.
So if I am running the motor 50% duty in one direction 50% of the time the motor is driven and 50 is braking?
Is this going to work or will I be producing huge current spikes?
I better like the idea of using IR2110. Those drivers have seperate inputs for high side and low side so I could drive only one IGBT.
Thank you!
Thank you!
