I may have a spare but I doubt that small. I will probably need to take this up tomorrow. Thanks again for your help.
Second test I removed the channel 3 plug and touched the tip leaf spring and then R21. One end I get sound on the ohm scale and it reads 000.1 ohm scale. Other end reads OL but then saw 199.4k.
Did you check all the highlighted components prior to placing an order?I sure hope this fix does it.
