Hi Guys, I am new here and could do with some advice. Basically I know nothing about electronics so please bear with me.
I have a message display board that I need to modify. It works off four 1.5v batteries and has a remote infra-red sensor built in that allows me to change the message via remote control.
It has a power management system built in that activates the message board when it detects vibration or motion and that allows me to activate or change the message. After 30 seconds of no activity, it shuts down again to save battery power. The problem is that the motion/vibration sensor isn't sensitive enough and so i have to shake it for the device to wake up. What i want to do is remove the motion sensor all together...or by pass it so that the message board is live all the time and looking for a signal from the infra-red.
I am not worried about depleting battery power as I intend to link it to mains power. That bit, I know how to do but i cannot work out where the motion sensor is on the board so I can over ride or dismantle it. I think I may have found it but if i have then i am not sure how to by-pass it.
The image below shows the back of the board.
Now I used a soldering iron for the first time ever and disconnected the Peizo speaker on the right hand side thinking that it may have a vibration/motion sensor built in. But the message board continued to work but without sound. I reconnected it and looked at the little silver box with the black ball situated that has three legs attached just below the infra red receiver. I covered it in insulation tape just to make sure that it wasn't part of the infra-red receiver and the device continued to work. So either it is the motion sensor or i havent got a clue what it is. I desoldered it from the board and the device stopped working completely and so i reconnected it. If that little silver box is the motion sensor then can i remove it and replace it with some sort of connector to maintain the circuit and ensure that the device still works without a motion sensing requirement and if so then what sort of connector would i need.
If it isn't the sensor then where would it be....part of the infra-red bulb perhaps?? There is nothing on the other side of the board except for capacitors, resistors and another silver tube like device that might be the programming unit for the messages.
Many thanks for your attention.
