Grounding in Rs485 for long wire communication
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. I have two devices which are are very far order of 10's of meters. Final distance depends upon installation site.
2. Now what I read is Rs485 is three wire(not 2 wire communication which is misconception), so common gnd should be there.
3. Now both devices are powered by their own power supply(or battery in case power goes)
4. How do I do common gnd for them. What I read running 3rd wire parallel to A&B of Rs485, large gnd loop will form? So what's the solution for it?
Papabravo
Joined Feb 24, 2006
22,113
RS-485 is full differential which allows for a considerable common mode ground difference between two nodes. There are other systems (CAN in particular) that are quasi-differential with respect to a common ground. CAN transceivers do allow some common mode differences, but it is more limited than RS-485.
