Grounded DC supply
Hymie
Joined Mar 30, 2018
1,347
To produce a negative rail with reference to earth, you need a centre tapped transformer, and cannot use the single secondary winding as originally proposed.
Control Dave
Joined Sep 2, 2023
34
What you said is what I intended. To be completely clear, the -ve end of the capacitor should go to the same 'ground' as the centre tap of the transformer. You should get about 31V DC out in theory. I would go for a capacitor rated at 50V or higher. It would be good to check the output voltage with a multimeter before you connect your amplifiers to it.
Hi Dave. Thank you for all your advice you really know your stuff. It worked a dream. Tried to send quick video but wont upload.20230908_112657.jpg
Control Dave
Joined Sep 2, 2023
34
Thank you for letting us know the outcome. Often the original posters just don't come back and the regulars here just have a discussion amongst themselves about the problem.
Are the new amplifiers outputting sound okay now?
Hi Dave yes the sound is perfect absolutely no hum. Just to fit a tone/volume board and job done. Thanks again.
Dave
