Graphic Equalizer-Baxandall
tam72f1
Joined Aug 19, 2014
15
I found a design on the internet and i want to make a circuit from this design but i don't understand about it, such as how to calculate some values: center frequencys, resistor.... I want to understand about because if have some problem i can repair and calculate again some value!
Does anyone help me calculate this circuit!! Thank you very much
Alec_t
Joined Sep 17, 2013
15,121
Welcome to the forum.
The calculations would be quite extensive. I suggest you download (free) the LTspice simulator from Linear Technology and run a simulation of the circuit. That will enable you to try different component values and study their effect. Let LTspice do the calculations for you! ;)
