gopher wigwag wiring problem?
Poor old sod
Joined Jul 25, 2017
156
wires on gofer orange, yellow, white. same connector pattern, mirrored on wigwag:
orange, yellow, white. old wigwag identical, both 45deg active 5K rehostats.
batteries charged 25v. white wire is wiper, and fed via max speed limiting rehostat, 25K from switched power on wire in loom.
Es ist Kaput. Es gehe nicht. 0.0V orange to yellow with main power on, switch working. Es war OK until wigwag changed..
have damaged battery charge indicator. how to wire single 12v LED as power on telltale for 30.0 - 23.0v, pls?
possible operator error-if wigwag not neutral on power on, or wiper o/c, wigwag not powered.
