good day everyone. can plss someone help me to calculate this circuit.
agentperry15
Joined May 19, 2023
35
i tried using 1 V at 1kHz and the value of output is now 1.74. I tried to use the formula gain=vout/vin thee value that shows is the same which is 1.74. what should I do?
Ian0
Joined Aug 7, 2020
13,317
It looks like a circuit that should work.
What are the DC voltages at the emitter and the base of Q1 and at the junction of R12/R13?
Ian0
Joined Aug 7, 2020
13,317
because I'm measure the voltage of R12 and R13
When I said "the voltage at the junction of R12 and R13" I mean the voltage between the junction of R12 and R13 and ground.
You probably realise that any voltage measurement has to be the voltage between two points. If someone asks for a voltage reading and only specifies one point, then the other point is the circuit ground or 0V.
Ian0
Joined Aug 7, 2020
13,317
In order for it to amplify, the output voltage when there is no signal should be about half the supply voltage.
ericgibbs
Joined Jan 29, 2010
21,654
Hi Ian,
I have checked my asc circuit against his original circuit post #1 circuit, it checks out OK.?
I have set RV2 at maximum and RV1 at 50%.
Attached the asc file for reference, please look it over.
E
@Ian0
I see a wiring error on my asc file correcting !!!:(
MrAl
Joined Jun 17, 2014
13,923
pllss help me to solve for the voltage gain, the input and output impedance, and the power efficiency of this circuit. I'm really struggling understanding this. I'm just 1st year engineering student and I only know basics. plsss help me. thank you
To do a theoretical analysis the first thing you have to do is pick a model for your transistors. There are a few different models but you probably dont want to use one as complicated as a full spice model to start out with. My suggestion is that you use the current controlled current source (CCCS) model. That's where you use a CCCS and assign a gain based on some Beta like 50. So each transistor is a CCCS with a current gain of 50.
That would get you started, but to go one little step farther into matching this up with reality, i would suggest adding the base emitter diode to the model. That just means that you include a diode with the CCCS where that diode becomes the base emitter diode. That means that all the base current flows through that diode, and the cathode (NPN) connects to the lead you assign as the emitter with the CCCS. Now when the transistor is working, you'll see various currents but you will also see a base emitter diode voltage drop, and you can set that to a constant 0.7 volts to get started. That means the diode will actually be a voltage source of 0.7v as long as the transistor is always biased correctly, and it usually is with amplifiers. For a PNP transistor the 'diode' anode connects to the emitter instead of the cathode.
You can still gain insight without the base emitter diode (0.7v voltage source) though.
The drawing shows two NPN models, one with the base emitter diode source and one without it.
To make the PNP models, reverse all the current arrows and the Vbe voltage source polarity.
Note the base current always flows into (or out of) the base and out of (or into) the emitter. That current is sensed by the CCCS and is multiplied by the Beta and that becomes the collector current. For example, if you have 1ma flowing into the base and the Beta is 50, then the collector current is 50ma and the emitter current, being the sum, would be 51ma. That would be true with or without the base emitter diode voltage source.
To use any of these or any other models you have to replace every transistor in the schematic to one of the models. You can use different Betas for the transistors if you want but it's easier to set them all to the same value to start with.
Because there are so many transistors in your circuit, I wont say the analysis by hand is going to be easy :)
At the very least use some math software after you write the equations.
