Good 5 Watt Amplifier Chip?
65musclecar
Joined Sep 28, 2017
12
Hello AllAboutCircuits Forum,
This is my first post! I'm building a portable audio amplifier. I'm hoping for stereo 2 x (5W - 7W) power into 8 Ohms, using lip0 3.7v ~1000mAH battery. I'd like the charger to be integrated on the same board if possible. (kind of like this https://www.adafruit.com/product/2130 plus this https://www.adafruit.com/product/2465) I've tried the PAM8403, but it's only does 3W max. The Diodes PAM8610 has almost too much power and requires 12v. If I could find something close to the power of the 8610, but that can use 3.7v batteries, I'd be super grateful!
Thanks!
bertus
Joined Apr 5, 2008
22,909
You will have a hard time finding a chip that can give the 5 Watts at 3.7 Volts.
When you would use a double voltage of 7.4 Volts, the search would already be much easier.
Bertus
65musclecar
Joined Sep 28, 2017
12
Thanks for the tips! My project is really tiny so I'm hoping for a class-D amp microchip around the size of the Diodes PAM8403. I looked at a couple projects on youtube using the TDA and I will keep it in mind.
65musclecar
Joined Sep 28, 2017
12
Bertus
You are right! I am having a hard time! I hacked something together using this Oontz bluetooth speaker that is 2 x 5W and runs off a 3.7v lipo(18650 I think) but I couldn't identify the chips on the board. The main chip says JL AC1535cg690x b1
I'm definitely open to 7.4v. I just need to keep the whole thing really small. Any chip suggestions if I do 7.4v? and charger?
34,700
Do the math.
If the output swings from 0 to 4V peak-to-peak, that is 2V amplitude, which is about 1.4V RMS.
Power into 8Ω speaker = 1.4 x 1.4 / 8 ≅ 250mW.
BobTPH
Joined Jun 5, 2013
11,486
A bridged amp can can provide 4 times that or 1W.
You need 9V min to get 5W RMS into 8 Ohms in a bridged amp.
Bob
65musclecar
Joined Sep 28, 2017
12
Thanks for all the input! Sorry if I am asking for the impossible. The speakers in the Oontz product I referenced are 4 Ohms. I may be able to get speakers that are 4 Ohms for my project too. What is the best amp chip that will get me 5W per channel stereo into 4 Ohms?
65musclecar
Joined Sep 28, 2017
12
Thank you Crutschow!
That board looks good for 7.2v. I'm going to order a sample. I'm also looking for a evaluation board or an existing project that incorporates it so I can test it for my application without having to build it myself first.
Audioguru
Joined Dec 20, 2007
11,248
The TPA3144 amplifier produces 6 Whats into 4 ohms when its supply is 7V and its clipping distortion is awful at 10%!
You never want to listen to 10% of clipping distortion (maybe acid rock?) but the datasheet does not say how much power when the output is
below clipping which might be only 3 Watts. When the 2-cells lithium battery is fully charged at 8.4V then the power might be 4 Watts at low distortion.
A "What" is a very distorted Watt so that the power number is higher. Many amplifiers are falsely rated in Whats instead of Watts.
65musclecar
Joined Sep 28, 2017
12
That's funny!!! I remember going to buy stereo amplifiers as a kid and some of them were super cheap with enormous power ratings...they were definitely using "Whats" ha ha!
Do you have any other suggestions for a suitable chip? I'm powering some exciters that are 8 Ohms. I haven't found suitable replacements that are 4 Ohms. This question will probably show my ignorance, but would it be possible to modify a speaker to make it 4 Ohms instead of 8?
34,700
If you connect two 8Ω loudspeakers in parallel that will effectively give you 4Ω impedance.
Just make sure that the loudspeakers are in-phase otherwise you will get wave cancellation.
65musclecar
Joined Sep 28, 2017
12
Thanks! Unfortunately, I can only use 2 speakers and I need to be in stereo so I don't think I can run them in parallel.
ian field
Joined Oct 27, 2012
6,536
Thanks!
With the voltage headroom you mention, a BTL amp chip might just about do it. You should also take a look in the general direction of class-D.
With only 3.7V to play with, you should try to get 4R speakers - or use a step up transformer.
The TDA7052 works well down to Vcc=5V and 4R speaker, but IIRC: its only 1W - there may be something bigger in that chip family.
Audioguru
Joined Dec 20, 2007
11,248
I had a car where the speakers were 2 ohms for double the current and power of 4 ohm speakers.
Most or all the amplifier ICs we have been talking about are BTL and class-D but the supply of only 7.2V is too low for 5W into 4 ohms without severe clipping distortion.
