Getting the most from 433Mhz
Foreman1
Joined Dec 17, 2017
I I am a beginner I am currently working on a project that has 9 volt power supply with on-board 5-volt regulation I'm trying to implement 433 megahertz wireless RF link system I would like to get maximum distance I've seen several videos about different lengths of antennas to maximize performance as a half wave antenna I am wondering if I can create a quarter wave antenna say out of coaxial cable and some fittings I would like to use a smaller antenna as this project is going to be very mobile and I'm fearful of the long antenna .it supposed to be a hands-free battery operated device any help someone could offer I would welcome thank you
Papabravo
Joined Feb 24, 2006
22,115
Do you know how to calculate the wavelength of a 433 MHz. signal and divide that number by 4, to get the length of a quarter wave vertical? You will have a difficult time getting more range out of a smaller antenna. If you are willing to go larger there are some possibilities.
Reloadron
Joined Jan 15, 2015
7,977
The simple quick and dirty is a basic vertical antenna. Wavelength is calculated as the velocity of a radio wave in free space / frequency in Hz so roughly the velocity is 300 Million Meters Second / 433,000,000 = 692 mm Wavelength. If we want a 1/4 wave antenna we can divide 692 mm / 4 = 173 mm. So a vertical pole cut to 173 mm would suffice as a 1/4 wave antenna for 433 MHz. That is the crude and simple. The problem is this antenna is omni-directional so whatever power you have radiates in all directions. Using a directional antenna you get more distance but only in a single direction. A Google of 433 Mhz YAGI Antenna will give you some ideas. Also many small 433 Mhz boards have a small loading coil on the board right where the antenna is connected allowing for a shorter vertical antenna. Depends on your board.
Ron
BR-549
Joined Sep 22, 2013
4,928
Do you know how to dis-assemble a cable and fold shield....back up cable.
If you fold and roll shield back up cable at 1/4 length.......then cut and stripe center lead at 1/4 length........presto.......you have a dipole.
The cable may lie down your back or side. Or use very small cable with fishing pole attached to back pack vertically.
Foreman1
Joined Dec 17, 2017
Thanks everyone for all your help & suggestions..really appreciate your time.Can I ask another question, Please..Does anyone know is there a way to set up a point to point tranciever for a simple single square wave oscilation circuit..without an adrino .Not sending data characters just want to send on High off low between points.Can this be done with encode / decode IC.
