I'd like to start messing around with PIC development and I have a few questions since I'm not very experienced in the electronics side of things:
I'd rather not go through 9V batteries powering my board, so I was planning on using a DC adapter I have (9VDC 500mA). Here is the specs for it DC Adapter. Would this work OK if I cut off the barrel connector and connected the two wires to a +5V regulator circuit on the breadboard? I was planning on following this schematic for the 7805 regulator.
This may be obvious but I just wanted to make sure this was the proper way since I couldn't find any barrel jacks that would fit into a breadboard. I've done a fair amount of reading on electronics but not much hands on application so I don't want to do anything stupid.
BTW the PIC I plan on learning on is a 16F84A most likely or something close to that if it makes a difference.
Thanks!
Thanks!
