Getting a slight electric shock from metal frame - How to find fault?
Dodgydave
Joined Jun 22, 2012
11,395
I have 50 separate LED lights plugged into UK AC230v Sockets, each LED has its own driver, they are fixed onto metal framework which is also supporting draws and shelfs.
Everytime I open a draw or touch a shelf, I get a light electric shock, not painful but does produce a cracking sound.
Is this a cause for concern?
If you had to guess from experience, what would you say is the most likely cause of this, Also, would there be a straight forward way to diagnose?
It would be a very tedious and time consuming process to manually test every LED and its driver.
Do have a mains test screwdriver, or Dvm to test the metal frame for leakage?
DickCappels
Joined Aug 21, 2008
10,661
Also, if it is a mains power leakage, wouldnt it be better to locate the leak as opposed to just earning the framework?
Or is earthing the frame and leaving it there considered good enough
Similar to what @MaxHeadRoom wrote, put a resistor (I suggest 1K) in series with a wire from the shocking metal part to earth and measure the voltage across it, we can then calculate the annual power wasted, but beyond satisfying your curiosity, the information will probably not be terribly interesting.
Some ungrounded systems do have some 'natural' leakage, often not dangerous, but earth grounding should eliminate it.
This is true, keep in mind that a small leakage times 50 power supplies may no longer be "small" leakage. Also, AC current can go right through insulators - in that case we refer to the insulator as being a dielectric. As @MaxHearRoom suggested a couple of time, ground the metal frame.
I have a Mac Mini that uses the largest allowable leakage current (to help the internal power supply pass the conducted interference test). I simply ran a wire from an exposed metal part to the ground terminal on a grounded AC outlet - no big deal and I don't get shocked anymore. It should be very simple.
