- Joined Jan 23, 2018
- 28,358
Some of the circuit does not look right, and if there is only 2.2 volts on the regulated 5 volt line then certainly that is part of the problem. Is C1 leaky?? Or is the IC drawing far too much current?
It may be the pass transistor is open, and still, that 12 volts DC supply will not be adequate for evaluation of the rest of the circuit. Also, given that the signal connection is somehow through the power wires, using a regulated power supply is sure to prevent correct operation. The scheme that this arrangement uses to communicate back to the opener circuit is not completely clear to me.On closer look, the IC has 2.7V on pin 7 (DI) yet only 2.2V on pin 1 (VCC) which means the 5V reg is doing nothing. Backfeed from the IR LED monitor R7/D6 is actually giving the little bit of power. This leads me to believe R4 is open, but OP did not give many part values, or maybe D9 is leaky and stuck at 1.5V instead of 5.6V which seems a bit weird.
I've done reverse-engineering on other obstruction sensors like Liftmaster, Chamberlain, Sears.
I could draw a better schematic if OP is willing to give part values and another pic of the board top/bottom.
Garage door obstruction sensors are basically a one-wire bus with the three - IR transmitter, IR receiver, and door opener all tied together, in parallel.[...] The scheme that this arrangement uses to communicate back to the opener circuit is not completely clear to me.
