Generate pulses with a capacitor
AMIRAAM
Joined Dec 31, 2019
37
Hello everyone
I am new to electronics but I know some basics!!
I know that the current do not flow through the capacitor when it is full charged. That will cause the Led to be off after moment
Please what I have to add to be sure that the capacitor is completely discharged before another high state
Also if there are any other notes please I will appreciate any help
ericgibbs
Joined Jan 29, 2010
21,554
hi AMI.
This simulation shows the action of your circuit.
The LED is Lit for only a fraction of a seconds.. [ the LED current plot]
What are you trying to do.?
E
Added the Diode, increase On time to approx 0.1 sec.
ericgibbs
Joined Jan 29, 2010
21,554
hi Bob,
I don't think he is trying for a relaxation oscillator, just a button push, wait , button push ....
Hopefully he will tell us.
E
BobTPH
Joined Jun 5, 2013
11,633
Yes, it is interesting that they completely went out of style. I guess that is the fault of the ‘555 IC.
Bob
Audioguru again
Joined Oct 21, 2019
6,826
I used some 2N6027 things 50 years ago when they were called a PUT.
Maybe Amiraam does not see that in his circuit nothing happens after one LED flash if he keeps pulsing the button because the important diode is missing. EDITED.
Ian0
Joined Aug 7, 2020
13,248
I’ve seen them called programmable unijunctions as well, but they’re thyristors, so they have three junctions.
Apologies for being very literal!
AMIRAAM
Joined Dec 31, 2019
37
Hello everyone and thanks for your replies
BobTPH said
Simplest way is to use a Unijunction transistor.
BobTPH said:
He is trying to create a relaxation oscillator.
It would be good if Unijunction transistors are always available (something can be easily replaced)
Here I am not
trying to create a relaxation oscillator or something for excellent frequency stability (555, Crystal Oscillator …) but only simple delay timer
AlbertHall said:
Add a diode across the base emitter, cathode to base.
Ericgibbs said:
hi AMI.
E
So please can you explain to me how can the diode discharge the capacitor when the low state is applied
Audioguru again
Joined Oct 21, 2019
6,826
When the input is high then the capacitor is charged to 4.4V through the forward biased base-emitter and 2k of resistances.
When the capacitor is charged then it has no more charging current and the LED turns off.
Without the diode the capacitor does not discharge.
With the diode then the capacitor discharges through 1k resistor R2 and the diode when the button is pressed.
BobaMosfet
Joined Jul 1, 2009
2,211
Hello everyone
learn in a structured way- so much faster and gives you a solid foundation:
Title: Understanding Basic Electronics, 1st Ed.
Publisher: The American Radio Relay League
ISBN: 0-87259-398-3
sparky 1
Joined Nov 3, 2018
1,218
Another relaxation oscillator using a neon bulb (Ne2) as an active component.
(The circuit uses less than 1mA or low current and higher voltage.)
Some mistakingly refer to something like this as a voltage only circuit, raising the voltage is important and it can run for years but not magic.
