Heys guys,
I have a doubt in this circuit and need some help figuring it out.
Consider this following rough circuit:
The current source are solar panels which are charging the battery.
The voltage drop across the 0.01E shunt will give me the current value.
Here's my question
"What current does the shunt measure?"
I mean to say ,
Is it the current at which the battery is charging ?
(If this is the case,then the current consumed by the battery should gradually decrease as the battery reaches full charge.So i can predict the battery is fully charged when this current reaches 0.)
OR
Is this the amount of current the panels are forcefully pumping into the battery(solar current)?
(If this is the case,then the current flowing into the battery increases during the day and decreases at night)
Bear in mind that there also is an inverter(in this case we can consider the inverter as a load),so how would the current measures by the shunt vary with respect to the load.
Thanks in advance,
Arun
Here's my question
I mean to say ,
OR
Thanks in advance,
Arun
