Garden lights
garybuska
Joined Aug 12, 2014
23
Hello all
I am new here and have a question.
I have one of those round globes that are solar powered and has a single LED in it.
My question is how does the single two lead LED manage to turn different colors.
I have heard elsewhere that this is due to TWO LED'S combined into one package.
I have looked very closely and for the life of me I can not see two separate ANODES and CATHODES in this unit.
So how is this done?
I have noticed that the one common thing I have found in these items is the fact that they all use two AA rechargeable batteries.
I even discovered that if you take the LED out and connect it to a 3 volt battery it will change colors
anhnha
Joined Apr 19, 2012
904
18,104
Here we go again with rms power calculations!
Technically, you have to integrate instantaneous power over time to get the average power. There are various shortcuts, including using average voltage times average current. That's not correct, but is close enough for a garden light.
MagicMatt
Joined Sep 30, 2013
117
They'll have to be using an average anyway, since the power consumption of those colour changing LEDs varies slightly depending on what colour it is outputting at the time. Doesn't really notice on one... notices more when you're driving 250 of them on a string...
anhnha
Joined Apr 19, 2012
904
As you said, the average power consumption is calculated from instantaneous one.
Pavg = average {Pinst}
Pinst = i^2*R
Where R is the internal resistance of the LED. Yes?
Now for example, the power supply is an ideal battery 5V.
How do you calculate intansaneous power consumption?
I think an external resistor is needed to limit the current.
The specifications doesn't list current range, so how to know that range and from there calculate power consumption?
adamclark
Joined Oct 4, 2013
472
Ive got some of those solar garden butterflies that changer color. I figured it was just an RGB LED that had an ic changing voltages to make it cycle through al the different colors.. Im not trying to hijack your thread, but thanks for the math to figure rms power..
