Garage Door opener is tripping its circuit breaker
wayneh
Joined Sep 9, 2010
18,169
My LiftMaster garage door opener is 27 years old. I've replaced the drive gears once but otherwise it's been quite reliable. It's nominally 1/3 HP.
Recently it has started blowing its breaker intermittently. I think the rate is increasing. I removed the ~100W lightbulb but the trips continue. There are a few low wattage lights on the same breaker, including an outdoor "gaslight".
I once was looking at the lift when I hit the button, and saw a small flash as it tripped. At least once when it had tripped, I had to unplug the unit in order to reset the breaker. It worked normally when plugged back in.
I haven't opened it up yet but I'm just posting to see if anyone has previous experience that might explain all this. How about the limit settings? It occurs to me that it always fails fully closed.
MaxHeadRoom
Joined Jul 18, 2013
30,815
Have you adjusted the down/up limit, two adjustments on the motor unit itself.
You could reduce the down setting to see if any results, the other issue could be the start capacitor as a long shot.
Max.
jpanhalt
Joined Jan 18, 2008
11,087
Have you tried "grease?" Not the spray stuff used for cooking, real grease and mineral oil.
Also, if your door is coil assisted, might check that the coils aren't broken. That is probably an unlikely cause for something that developed over time.
Hymie
Joined Mar 30, 2018
1,347
Are you sure that the breaker is tripping due to an over-current event; and not earth leakage/ground fault?
wayneh
Joined Sep 9, 2010
18,169
The breaker is also 27 years old and back then, the breakers did not have those fancy capabilities. So yeah, I'm sure of that one. I do wish I had a measure of the current going outdoors to that gaslight. I don't suspect any problem (it's working normally) but I'd like to take it off the list of possibilities. The arc I observed certainly draws my attention to the lift unit.
wayneh
Joined Sep 9, 2010
18,169
Max.
I have not, but I think that may be the first thing I do next. I did install a new gasket on the bottom of the door last year and it's a lot beefier than the old one. Everything worked fine then so I never made an adjustment.
wayneh
Joined Sep 9, 2010
18,169
Not yet, no. It seems to move smoothly but I haven't examined it closely yet.
It's definitely coil-assisted but they're fine and the door is still working maybe 90% of the time. I can easily lift the door by hand if the power is out.
MaxHeadRoom
Joined Jul 18, 2013
30,815
This is why the suggestion on adjusting the down pressure setting, I had to adjust mine recently as it would not go down, it would move a foot and go back up.
Max.
jpanhalt
Joined Jan 18, 2008
11,087
That's a key observation. My home in Parma Heights (Cleveland) has solid, wood paneled doors (circa 1950). Could never lift them without the spring assist.
I would look for binding, clean and re-lubricate. Guide rails and drive. Don't forget the motor bushings too. Good to do both regardless of the reason for the problem. It is also possible the circuit breaker has gone bad and trips at too low a current.
wayneh
Joined Sep 9, 2010
18,169
Turns out the limit adjustment changes the force, not the position. Both the up and down force knobs were set to the line between low and normal. There’s also a high setting. I turned the down setting a little farther in the low direction. Nothing else obvious but I didn’t open it up yet.
jjwang
Joined Jul 1, 2021
Hi, how did you finally resolve the problem ? I think I have the exact problem as you encountered. Thanks!
wayneh
Joined Sep 9, 2010
18,169
It was the line to my exterior "gaslight". I think the wife probably put a shovel into the cable and every time the soil got wet enough, there was a steady current to ground. The opener just happened to be on the same circuit and occasionally threw the current over the limit. Not one problem since disconnecting the wires to the gaslight at the box where it had a photo sensor, by my garage outer wall.
jjwang
Joined Jul 1, 2021
Thanks much. An electrician came last week and found the problem- the same as yours which is the wire going to the post light in the front yard!
