function of IGBT drivers
falade47
Joined Jan 24, 2017
178
what are the function of mosfet or igbt drivers when you already have a high and low signal capable of driving the mosfet or igbt ?
MaxHeadRoom
Joined Jul 18, 2013
30,785
What drivers do you have in mind?
There are specialty drivers, dependent on the application and configuration, the IR2110 is one for example.
Max.
shortbus
Joined Sep 30, 2009
10,049
The driver allows the high side to stay above the Vgs level to turn it on, when using a Mosfet or IGBT as a high side switch. When using one as a low side switch a driver will give more amperage than a logic level signal, to turn the Mosfet or IGBT on and off faster. The faster the Mosfet or IGBT switches the lower the heat generated in it.
Sensacell
Joined Jun 19, 2012
3,787
The gate of an IGBT represents a large capacitive load, to attain fast switching speeds you need to be able to deliver high currents to charge and discharge the gate rapidly.
falade47
Joined Jan 24, 2017
178
Yea
Yeah..that is it..thanks..
falade47
Joined Jan 24, 2017
178
Thanks shortbus
