hey so im completely new to electronics. i just started troubleshooting some hp L1910 monitors.the problem i"ve encountered in many is that the screens comes on but after a few seconds in goes dark and stays dark, but u can still see what's in the background a little bit. now after opening up the monitor i"ve found the cause and it was bad capacitor now not all of them had that bulge on top. but also after replacing the one that i couldnt see directly if it was bad. the problem was fixed. the capacitor was an 1000uf/25v. in the circuit below u can see i identified it. the two chips cirkeld mosfets are N & P-Channel 30-V (D-S) MOSFET and IC801 is an OZ9938 it's a high performance, cost-effective CCFL (Cold Cathode Fluorescent Lamp) controller designed for driving large-size Liquid Crystal Display (LCD) applications requiring 2 to 6 CCFLs. The controller converts unregulated DC voltages into a nearly sinusoidal lamp voltage and current waveforms. the capacitor is connected between these two so that must mean these two chips are essential thus maybe explaining how important the capacitor must be seeing it causes the problem my question now is why is it that this particular capacitor is causing the problem? what is the function of it in this circuit cause capacitor have a lot functions depending on circuit right?
and how does it going bad effect the circuit?
