Front panel buttons doesn't work on AV receiver THOMSON DPL300HT
VonDrobac
Joined Aug 5, 2022
6
Hello
Got this old receiver for free with problem, none of the front panel buttons are responding.
I was able to turn it on with remote and everything seems to work with remote controler.
Found shematic (not best quality) and what i don't understand how this switch matrix works (or should work).
So on 6v a have 5.65v i guess its fine, only bad component on the board was C307 supercapacitor ( i assumed it is only for voltage stabilization and for now i desoldered it out).
I don't understand why we have both and pull up and pull down resistors on switch matrix, so when i press any switch i have voltage divider, and on ic input key-1 have only 0.5v (pull up resistor are larger) but ic does not respond . Is that ok ?
twohats
Joined Oct 28, 2015
617
Do you have +5v at pin 6 on connecter CN302 ?
Forgive me, if you are already beyond that point.
Good luck.......
abrsvc
Joined Jun 16, 2018
167
Check the voltages on each of the key input lines and key SEG lines. You likely have a "stuck" switch or an open line. A scope will be your friend here. Check the clock lines too.
VonDrobac
Joined Aug 5, 2022
6
Thank you for reply, checked some voltages and made some progress. On SEG3 and SEG4 measured only 1.2v so i desoldered one end of pull up resistors on those lines and all other buttons started to work.
Still cant figure out how i could have there only 1.2v when all switches are open, that means whole side
hanging it should be 5v?
For clock i have only analog oscilloscope but i guess can be done.
VonDrobac
Joined Aug 5, 2022
6
Just a quick update, desoldered few micro swiches even they measured ok with continuity (from those two SEG lines) and guess what, all lines now have same expected voltage. Tomorrow I will solder new ones and test it....
