Front load washer not turning on - How to diagnose?
elli
Joined Jun 12, 2017
37
Press the start button and nothing happens - no lights, no nothing. Prior to this, it was working fine.
This is what i've done so far...
Using a multimeter, i checked...
  1. Socket
  2. Plug fuse
  3. Power at the plug cable connector (which connects to the noise filter)
  4. Power by back-probing the other connector of the wire that goes to the washer at the noise filter (check out picture below).
  5. Random connectors at control board
What else can i do to find out where the problem is?
Dodgydave
Joined Jun 22, 2012
11,395
Usually the door lock needs to be closed, as this puts the mains on, ideally you will need a wiring diagram for your machine.
elli
Joined Jun 12, 2017
37
The door was closed when tested. I also depressed the spring loaded lock with a screwdriver just in case the door was defective, no go.
