From AC to DC (Motorcycle Headlights Question)
ChrisTsall
Joined May 16, 2018
41
Yes that is right. A dynamo is a DC power source for your electrics and charges the battery is have one.
The dynamo should not give out 1-5v as that's to low.
As previous message has said that the dynamo most likely dying or damaged and most likely needs replacing. How old is the bike? Is if its quite old it will be a 6v system and if that is true that dyno needs to at least supply 6v-7v to charge a battery ideally.
Thanks for the info ! I will check again the voltages .
ChrisTsall
Joined May 16, 2018
41
Yes. But before connecting the dynamo directly to the battery, install a rectifier diode in series to prevent a reverse current from the battery back into the dynamo. It that happens it will destroy your dynamo or kill your battery.
Look for a Schottky diode which is going to minimize the voltage lost across the diode. A 5A diode should be sufficient.
Perfect I am going to apply it then . Thanks !!
shortbus
Joined Sep 30, 2009
10,049
An alternator requires external power to drive current into the rotor windings.
While that is pretty much true in cars, most motorcycle alternators use permanent magnets instead of a field coil. That's the reason they also use shunt regulators too.
Alec_t
Joined Sep 17, 2013
15,152
Is your bike the XTC or the MadAss version?
From what I gather, both have a Bosch 6V magneto-generator (i.e. AC output devices) with multiple generator coils, those for the lighting each having one end grounded.
setsquar
Joined Oct 11, 2012
36
It's a Sachs 125cc , no battery fited . I thought dynamo was an AC generator because of the headlights performance .
this has I think has a permanent magnet flywheel generator so NOT a dynamo
as the output will be AC and some of these small bikes only produce 30watts at 6volt
what wattage is your headlamp bulb
and from what you say its not producing enough volts/current to run the lights so trying to also charge a battery as well will not work.
ian field
Joined Oct 27, 2012
6,536
Hello , I got a motorcycle (an old one) and I need to fix my headlights, because their lighting isn't powerful enough. So the dynamo - electric machine gives 1~ to 5~ Volts (5 Volts when I hit the gas too much) . As a result with 5 Volts , the headlights shines enough and I want to keep that light consistently . The problem is that I can' keep that light steady because, I don't hit the gas for ever .As a result the light's level is going down . I have tried changing my headlights with lower watt lamps and it kind worked , but I can't use lower wattage lamps for ever . Do you guys have any idea ? Will an amplifier that changes the ac to dc work ?
Sorry for my bad English and thank you so much for your time !
Sounds faulty to me. AC lighting is usually a grounded generator winding and any rectified supplies are half wave. If it isn't potted, you might be able to isolate the grounded end so you can feed a bridge rectifier. There are all sorts of problems - if there is a DC system, you'll have to re design that and probably add a regulator.
