Frequency Doubler.
Ferret
Joined Feb 27, 2009
2
I hope someone can help... Basically, I own a 2000 Ford Mondeo 1.6, and my speedo is reading half of my actual speed. Now we've got it down to something inside the gearbox.
So, I now need to bring my speedo up - And the only method I can think of using is a frequency doubler.
The frequency doubler will need to be put on the wire for the VSS (Vehicle Speed Sensor)
I believe it to be a sine wave, at 4000PPM.
Thanks alot,
Ferret !
jpanhalt
Joined Jan 18, 2008
11,087
That is strange. If it is exactly 2:1, that would also be a bit strange for gearing where the center distance between the driving and driven gear are probably not adjustable.
How do you know it is in the gear box and not in the instrument cluster?
John
Ferret
Joined Feb 27, 2009
2
I'm not entirely sure if it's 2:1, but it's as near as dammit !
I know it's in the box, because I got a new VSS and wired it direct to another set of clocks... So the only thing that's left is something in the box !
