Frequency doubler - low frequency- square wave
ian field
Joined Oct 27, 2012
6,536
I am using a hall effect device to measure the speed of an enclosed shaft.
The output is fed to a cheap pulse counter that can be configured to display pulses per sec or pulses per min.
The speed of the shaft varies. The normal range is from 5 rotations per sec to a max of 250 rotations per sec.
The problem is that the pulse counter is neither stable or accurate below 10 pulses per second.
The easiest solution is to the double the input frequency.
The counter has x1 , x2 and x10 multiplier for the display.
The doubled the input frequency is easily corrected at the display.
I am hoping some one can direct me to a circuit that can perform the frequency doubling function I require.
Thank you
do what WBahn said - or there's a few electronic methods, one of them uses an XOR gate but I don't remember the details.
38,870
Should the signal voltage from the HE sensor be limited before feeding the signal to the 4077.
I think the spec sheet states + 0.5 volt
Not limited, amplified.
The circuit needs a signal voltage equal to the supply voltage.
For + 0.5 volt signal you need to add a comparator as I suggested in post #21 to boost the signal.
