Ok, then you need to use the word, "signal" instead of "frequency"Thanks
You Right
A signal can be amplified
- current gain
- voltage gain
- combination of both
my means exactly both of them
amplifier Current and Voltage of frequency
Thanks
this is Powerfully?
any n-mosfet can do this?
Make sure you use a "logic level" mosfet. That is, one that turns on completely when the gate voltage is at 5 volts (or even less).
Follow the words in #7 carefully. He has given you the details you need. Search for "MOSFET switch" for more general information.You Can Give Me a Circuit For Example ?
What do you mean by "Powerfully"?Thanks
this is Powerfully?
FIXED - I Hope!Oh wait, Gopher made a booboo. He meant "gate" where he wrote "drain" in lines 5 and 6.
