Fourier transform
ecesoul
Joined Sep 8, 2012
8
sorry for the word 'tricky'. It was asked as a multiple choice question in an exam with limited time.So I thought there might be some easier way than conventional.
I thought about initial value theorem, but don't know whether we can use it in Fourier domain
22,111
Step 1 is to apply the double angle formula
sin2ω = 2sinωcosω
Step 2 is to replace the cosine terms with 1 as ω -> 0
Step 3 is to take the limit as ω -> 0 of sinω/ω which is the well known sinc function, which has a value at ω=0 of 1.
Step 4 is to write the final answer of 4.
That's the trick if you can call it a trick.
33,142
You can get it even more directly by noting that it can be written as:
f(w) = g(w) h(w)
Where
g(w) = 2cos(w)
h(w) = sin(2w)/w
The value of f(w) as w goes to 0 is simply the products of the limits of g(w) and h(w) as they individually go to 0 and, since g(w) is well behaved at w=0 (it's equal to 2), we can focus on h(w).
This goes to 0/0, which is one of the forms for which we can apply L'Hospital's rule by taking the ratio of the derivatives of the numerator and denominator. which gives us that h(w) as w goes to 0 is 2cos(2w)/1, which evaluates to 2. Taking the product gives us 4.
Another way is to recall that, for sufficiently small angles, sin(theta) is approximately (theta). Well, approaching zero certainly qualifies as 'sufficiently small', so sin(2w) is about 2w, giving us:
f(w) = 2cos(w)(2w/w) = 4cos(w) for small w. For w approaching zero, this approaches 4.
ecesoul
Joined Sep 8, 2012
8
Sorry I think you missed an important point
H(jw) is given ie in frequency domain
But we have to find h(0), which is Limit t->0 h(t) ,this is in time domain
So we have to find inverse transform, I dont know how that could be done in this case
33,142
You're right. I thought you were looking for H(0), not h(0). My vision is getting blurry enough that I have a hard time telling the difference between h and H. I got focused on the removable singularity and thought that was what wa giving you problems.
Now your comment regarding the initial value theorem makes much more sense. I'm not sure whether you can apply it or not. I thought you probably could, but haven't been able to confirm that and have seen some things that imply you can't. This makes sense because the Fourier transform is for periodic signals that exist for all time, so the very notion of an 'initial' or 'final' value is problematic.
Now, given a Laplace transform, you can convert it to a Fourier transform by setting s=jw. Depending on whether information was irretrievable lost in that process, you might be able to get the Laplace transform back by setting w = -js. But I'm skeptical that this is going to be valid.
Sorry I don't an answer or even firm guidance for you, but hopefully something I've said will get you to looking in a direction that eventually leads to someplace worthwhile.
Tesla23
Joined May 10, 2009
560
Given fourier transform H(jw)=(2cosw)(sin2w)/w.
what is h(0)?
please help, i think it is a tricky question
given
\(h(t)=\frac{1}{2\pi}\int H(\omega)e^{i\omega t}d\omega\)
then
\(h(0)=\frac{1}{2\pi}\int H(\omega)d\omega\)
you need to do some trigonometry on \(H(\omega)\) to evaluate this using some standard integrals
