Fourier Transform Solution
kaan_45
Joined Apr 8, 2017
5
I can't understand that transition from the solution. Can you help me? How the solution got 1/(B-a) and how is the multiplication removed of the Y(f).
MrAl
Joined Jun 17, 2014
13,864
Hello there,
That lower result is a partial fraction decomposition of the upper expression.
If you replace j*2*pi*f with just a single variable 's' it makes it a little more clear as then you start with:
[1/(a+s)]*[1/(b+s)]
Try to do a partial fraction decomposition on that and see the result you want pop out :)
Then just replace 's' with the previous j*2*pi*f and you're done.
