Formula help
biferi
Joined Apr 14, 2017
539
I wanted to know if I am doing the Math Right to find out what Amps are in every Foot of an LED Strip I have?
The LED Strip Length is 16.4 Feet.
The LED Strip is Rated 3.4 Watts Per Foot.
The LED Strip is Rated at 12 Volts.
So if I use the PIE Formula like this will I not find how many Amps are in every Foot?
3.4 Divided by 12 = 0.283333333 Amps.
Is this how many Amps are in the Whole 16.4 Foot LED Strip?
Jon Chandler
Joined Jun 12, 2008
1,645
Watts = volts × amps -->
amps = watts / volts (this part you got)
amps = 3.4/12 = 0.28
But the rating is in watts per foot
So the strip draws 0.28 amps per foot
So the entire strip draws
0.28 amps/foot × 16.4 feet = 4.6 amps.
