Forcing electric motor in opposite direction rotating
leod
Joined Dec 21, 2020
18
Honestly, I cannot see how a rope connected to the motor axle is going to work.
Imagine trying to pull back a car that is already running forward.
Why not simply a rope attached to a very large tension spring?
I thought about rope and spring, but it cant switch diffuculty level plus there are many more functions which springs cant offer.
shortbus
Joined Sep 30, 2009
10,049
And there are more things that you motor can't do. In normal *fly* type exercises you are using both the pull and retract to strain the muscles, that is one of the things that make that type exercise so effective. With you motorized retract it won't force the muscle to keep the weight under control, and could even be dangerous if it is too fast.
28,279
Please consider the physical size oof a spring that can stretch a whole meter and then retract. Now if it needs to provide some force, it will be big. In addition, the force to stretch a spring varies as it is stretched, while any exercise machine keeps a constant effort as required. Mechanical reality gets big and bulky sometimes.
28,279
The TS has an idea on how to make one delivering the same performance while being mechanically much simpler, far more adjustable, more compact, and with probably quite a few unique computerized features. Certainly a programmed servo motor could do it all, but doing it with a simpler motor and control setup would make it unique and able to be patented.
leod
Joined Dec 21, 2020
18
Just found out that Tonal is already making such machine, they also got 200 m investment. Anyway, they use magnet resistance motor.
28,279
"Magnet Resistance Motor" sounds a lot like an induction motor with DC applied. So it might not have patent protection. And the features that can be added by means of computer control could be what sells the product. So if there is a desire to compete, get a copy of their patent and see what features are not claimed. Those are the ones to go after.
leod
Joined Dec 21, 2020
18
  • Magnet resistance motor set - pancake motor with torque controller attached on pancake motor, it is DC brushed motor. Existing machine is totally different from my idea in shape, applications and other things, only motor type and general use is somehow same
28,279
Really, an induction motor would be a better choice for long life and smoother braking. Not as linear torque to current relationship, and not as light as a pancake motor, but certainly worthwhile investigating. And it would be much farther away from the existing patents.
28,279
And much larger.
Sometimes marketing has shown that making some things a bit bigger sells better. Not all folks want the dinky little product, sometimes bigger is better.
And certainly there are more versions of induction motors available than pancake motor models.
It was not made clear, I don't think, as to if the TS was plannng on making one machine for personal use or actually going into production on this concept. For one individual the induction motor could be simpler, easier, and cheaper.
