For genius people
dakanat
Joined Nov 12, 2008
25
The super-heterodyne receiver has an IF of 470 kHz for AM and is tuned between the following frequency range 500 kHz – 1500 kHz.
· What would be the range of frequencies must the Local Oscillator cover.
· what would be an acceptable bandwidth for the IF amplifiers.
What would the effect be on a selected signal, if the bandwidth were twice as large as necessary?
hgmjr
Joined Jan 28, 2005
9,027
Is this question related to school work?
If so, then let me know and I will move it to the "Homework" section where it belongs.
hgmjr
hgmjr
Joined Jan 28, 2005
9,027
As I recall, 10.7 MHz is the IF associated with FM. Your original post indicated that your question was about AM. If AM is the subject, then beenthere is correct. The AM IF frequency is most often 455 KHz.
hgmjr
beenthere
Joined Apr 20, 2004
15,819
One problem with the specs given is that no figure for station bandwidth is given. The IF response is necessarily tailored to the signal bandwidth.
Bertus' link give the information necessary to figure the local oscillator frequency.
