Hi everyone
I've had success with my 12v ATX supply but now I'm in a position where I need a more powerful regulated DC supply with an adjustable range of at least 30-50V @ 20A max. This is my first power supply from scratch so I figured that linear would be simpler to understand and construct than a SMPS. Having searched through the forums for LM317 high current supplies I have found some very helpful threads, mainly this one
LM317 thread link
So after viewing other circuits and consulting the LM317HVT datasheet I have come up with the following design which ideally would give me a maximum voltage in-out differential of 60V. At such a high differential only a small current <100mA can flow through the regulator so at any voltage out value I need to limit the regulator current flow to 100mA.
T1 is a 240/50V(x2) toroidal @ 1kVA with both secondary's wired in parallel, BR1 is undefined at the moment and C4 is the smoothing capacitor with a higher enough value to assure <10%ripple @70.7Vp 20A load. The bypass circuit I have used is basically the one from the TI datasheet with a few adjustments.
1)BD744C is replacing the 2N2905 as it can handle the higher voltage, my worry here is that it has a significantly higher collector cut-off current than the 2n2905.
2)The 3x TIP73 mentioned in the datasheet seem to be unavailable so I chose the BD743C complement to the BD744C. So hopefully this will distribute the max 20A over all 3 NPNs and the base current should be kept down to about 270mA and the PNP base current requirement about 40mA. Assuming R2 is there to limit this current to the PNP then if I estimate I have 68.9V max from 70.7 Vp after FWB(1.2V) and R1(0.6V) voltage drops I get a resistor value of 1.8K (2.8W diss.).
3)Diodes have been added to protect from capacitor discharge across the regulator.
Now the problems I have come across are as follows:-
1) I am unsure as to the value of R1 as I need to limit the current through the regulator at any output voltage. I have read this discussed in the thread linked above however I couldn't reconcile it with my design as it required the output voltage from the regulator to be less than half the input or the maths didn't work. (link post #27)
2)R4 is only described in the datasheet as "minimum 30mA", not sure as to it's purpose but I have set it to draw a minimum of 30ma across the range of output voltages with a max power dissipation of around 10W. Not great not sure why I need it.
3)V1 and V2 are used for voltage adjust and I was aiming for a coarse and fine setup but have I got the ratio and configuration setup correctly for this application?
4)When using the 3xNPNs in parallel configuration do I need to add additional base resistors?
5)Would it be advisable to add additional circuitry for inrush current limiting and short protection?
Note about the load: The load this is primarily designed for will be a Royer oscillator induction heater. Ideally I would like to have 30-60V output so I can experiment with inputs but if a wider voltage range is attainable this would be preferable.
Thanks for taking the time to read my design everyone and if you can help or see any improvements/faults you wouldn't mind sharing I would be really grateful. xD
Thanks all
P.S. I have attached datasheets for quick access.
LM317 thread link
Thanks all
