Hi everyone...
I'm trying to find a way to display 3 plots with different time bases so that the modulation can be observed!
I mean, I want to modulate a carrier signal by a message signal using FM technique but as the message signal frequency is a few thousand times lower than the carrier frequency, I'm not being able to plot the 3 signals, message, carrier and modulated signals in a way that we can observe the modulation effect.
The signals are:
m (t) = sin (2*π*fm*t) V, where fm = 10kHz
c (t) = sin (2*π*fc*t) V, where fc = 10MHz
The modulated signal is:
But I'm using another equation that I suppose to be equivalent to that one!
y = vc*sin(2*pi*fc*t+m.*sin(2*pi*fM*t));
the result is this:
I don't like any of the results... Not even the message signal looks like a sin wave... Also the amplitude is weird I don't know why!
If I use lower values, like fm = 8Hz, fc = 100 Hz and modulation index of 10 (same as before) I get a lot better results...
Why is this? Why can't I use the script for higher values for frequencies?
The signals are:
the result is this:
clc
clear all
close all
t = 0:0.001:1; %upto 1000 samples
vm = input('Enter Amplitude (Message) = ');
vc = input('Enter Amplitude (Carrier) = ');
fM = input('Enter Message frequency = ');
fC = input('Enter Carrier frequency = ');
m = input('Enter Modulation Index = ');
msg = vm*sin(2*pi*fM*t);
subplot(3,1,1); %plotting message signal
plot(t,msg);
xlabel('Time');
ylabel('Amplitude');
title('Message ');
grid on;
carrier = vc*sin(2*pi*fC*t);
subplot(3,1,2); %plotting carrier signal
plot(t,carrier);
xlabel('Time');
title('Carrier Signal');
grid on;
y = vc*sin(2*pi*fC*t+m.*sin(2*pi*fM*t));
subplot(3,1,3);%plotting FM (Frequency Modulated) signal
plot(t,y);
xlabel('Time');
title('FM Signal');
grid on;
clear all
close all
plot(t,msg);
xlabel('Time');
title('Message ');
grid on;
plot(t,carrier);
xlabel('Time');
grid on;
plot(t,y);
xlabel('Time');
title('FM Signal');
grid on;
