Flyback Zener causing oscillations
patpin
Joined Sep 15, 2012
405
I tried to sim a part of an ignition system (car coil).
I include asc and lib.
When I put a flyback Zener over the IGBT I see oscillations on secondary, which I don't want.
Further I do not understand why the current through IGBT drain/collector is so low.
Can someone look at it? Thanks
AlbertHall
Joined Jun 4, 2014
12,663
The type of ignition system using points and a coil also has a capacitor across the points.
When the points are closed a cureent builds through the coil primary.
When the points open that current continues to flow and charges the capacitor. The voltage across the coil primary rises to around 300V and this is transformed to ~10kV across the secondary.
Your circuit has no capacitor and a zener would limit the peak voltage across the primary.
Also it seems that the RB238T100 is not a zener but instead a schottky diode with a maximum reverse voltage of 100V.
patpin
Joined Sep 15, 2012
405
Thanks for info on RBT . I read the reverse voltage is max. 600V in real life. On my sim it was 1.8KV.
Max Reverse voltage 600 or 1.8Kv?
What would be the most appropriate: Zener on the coil or on IGBT?
And should I go for low Vf and what zener tension? 20V?
Should I add a capacitor. (In the original ignition (electronic) there was a .1µF 600V condenser over a power transistor.)
