Hallo all,
Is there anyone who did a project with LT3748 Flyback converter?
I am designing a circuit with LT3748 such that the input voltage is standard 24V and the output voltage is 12V@2.5A. I designed my own planar transformer that had Nps 3:2. The problem, I am facing is that there is lots of power wasted in the mosfet. Is there a way to reduce the losses in the mosfet without adding a snubber circuit to the design?
and also the output is not exactly 12V insted 11.5V at light load conditions(R=5Ohm).
I am simulating for the worst case senario that the coupling factor is 0.98 instead of 1, since I dono wat is the exact Coupling factor of the transformer yet!!
Thank you.
Thank you.
