and what exactly is that supposed to tell us? you measured what, where using what and got what result?Hi everyone, i have bought this Fluke 73 series 1 but it's not turning on, I can't find schematics for the series 1 i have found only series 2 and 3, and based on that i have tried the test points and i got wrong voltages, is there any way to fix it! it got some corrosion that i cleaned but no luck
No sign of life at all, no displayyup, it looks like it had date with Zeus...
how does it behave when you power it on? any sign of life? anything on display?
Just a cutout (maybe for thermal, solder or testing) under the battery.That's only a part of the chip on the other side. Looks normal.I don't like the looks of this. Is it really broken off as it appears in the photo? Whatever that chunk is seems to be directly opposite the multi-pin chip on the other side of the board. Is it maybe a heat sink of sorts?
Ah, it's an innie, not an outie! I saw it as a broken rectangular object, not a hole.Just a cutout (maybe for thermal, solder or testing) under the battery.That's only a part of the chip on the other side. Looks normal
Sorry for my late reply, and thank you for your efforts and help!Just a cutout (maybe for thermal, solder or testing) under the battery.That's only a part of the chip on the other side. Looks normal.
I have my old 73 that still works (10A section was lost decades ago)
View attachment 373112View attachment 373118
Negative battery test point.
Battery 8.84V
Switch on ACV, measured from the top going clockwise.
View attachment 373116View attachment 373117
0
0
8.84
2.87, probe connect here causes display to change.
0
5.75
8.84
8.84
8.84
5.75
5.75
8.84
To the OP, check these voltages with a fresh battery. Report back here, I'll be glad to help if possible.
1 Series Oscilloscope | Test & Measurement | 0 | |
| 7 | 7400 series's | Digital Design | 18 | |
An eBay Fluke 8840A gamble... | Test & Measurement | 6 | |
New DMM. FLUKE-15B+/EUR or some UNI-Ts | General Electronics Chat | 14 | |
Fluke 114 deffective pls help me | General Electronics Chat | 9 |
