Fluctuating DC
DickCappels
Joined Aug 21, 2008
10,104
Depends on the IC. I even switched a crystal controlled microcontroller once at 50 Hz using a 4 MHz crystal. It would wake up, run a few dozen clocks, then go back to sleep.
Some analog circuit will also run for brief periods if you are careful but you will probably have to accept the fluctuation frequency component in the output.
