Flat power cable
ericgibbs
Joined Jan 29, 2010
21,559
hi Audio,
Welcome to AAC,
I have sharpened up your image.
If it was my repair, I would remove the flat cable and replace with regular wire, back soldered on those two connectors.
E
AlbertHall
Joined Jun 4, 2014
12,652
There are two common types. On one the white part of the connector lifts up, then you can insert or emove the cable, then push the white bit back down. On the other sort, the white part pulls out (downwards in your photo), then insert or remove the cable, then push the white bit back into connector.
