Thank you Mr Ya'akov.. These are indeed cheap quality ones distributed in my local intended for low price products. Thank you so much for you analysis! May I have your opinion on the main component? Do they use different methods in the main components?Welcome to AAC.
They are both cheaply made boards, but, the first one has fewer components, open relays, and what appears to be an inferior PCB substrate. All of which suggests severe value engineering. In value engineering products are designed to a price............
Yes they do have enclosure.. these two I got from opening their case.. Thank you for your analysis MisterBill2. As you said, I do find trouble more in using the open relay oneThe quality of the circuit boards……….. It works but it is not a good design, nothing is protected from short circuits or physical damage. Do they mount in an enclosure?
At a guess, a standoff to keep the housing from being compressed against the relays.Even when I examined the close-up photo of the open relay arrangement it s not clear if the two relay devices are in a latch/unlatch arrangement, or if they are simply mounted very close. So I am wondering about that, do they function in a latch/unlatch manner?
Also, that open wire does not appear to have any electrical connections below the PCB, so it might not be a resistor like I had guessed. Does the TS see any electrical connections to it on the solder side of the PCB?? If not, what is the purpose of that wire??
That’s what it looked like to me initially, but it seemed overly complex given how tightly controlled the BoM appears to be on that board, using so much large gauge wire and having to form it appeared off. Maybe it is a shunt and mechanical support.By open wire, do you mean the square-wave looking shunt? That's a current sense shunt, it connects one of the off-board terminals to the lower relay, it's the same as the shorter, straight shunt on the other board. They would both be used by the op-amp for current sensing I would expect. I would think that it is longer (and so probably a higher resistance value) on the second board because they use different op-amps and the current sense voltage may be set differently.
| Thread starter | Similar threads | Forum | Replies | Date |
| L | LED Flasher Help | Digital Design | 20 | |
Electronic Circuit Help - Need timer/flasher circuit. | General Electronics Chat | 8 | |
| D | Problem with flasher relay | General Electronics Chat | 6 | |
| L | Automotive turn flasher wiring relay | General Electronics Chat | 9 | |
| S | How to connect 2-pin Flasher Relay | General Electronics Chat | 14 |
