fkasher led on soldering iron
res1980i
Joined Feb 14, 2018
stays lit while heating uo but then fashes wen at the right tempurature which is really anoying i would like it the other wsay round its a yihua 937d its a cheap copy of an hakko anyone please help thank you
regards
rick
Dodgydave
Joined Jun 22, 2012
11,395
You can't unless you modify the circuit, the led is across the heater, and is controlled by a triac, when heating it's on, and when at temperature the triac is pulsed by the integrator to maintain the set temperature .
