First time using MOSFETs project
djsfantasi
Joined Apr 11, 2010
9,237
Are you familiar with shift registers, like the 74HC595? This chip is often used with Arduinos to increase the number of GPIOs that can be controlled. It is an 8 bit shift register that can be Daisy chained to provide as many outputs as you need. Thus, you can control 100+ outputs with 4-5 pins.
dl324
Joined Mar 30, 2015
18,326
The circuit is showing only 2 led box individually controlled but my project have 200+ i/o with 5 arduino mega and around 200leds to power. So using less pin is important.
I'm controlling 64 LEDs in a 4x4x4 cube arrangement with 7 I/O's on a Raspberry Pi Zero W. I could have used fewer I/O's, but my design was a compromise between circuit and coding complexity.
When I get around to an 8x8x8 cube, I can stay with 7 I/O's and add more hardware. Or use 4 more I/O's to keep the hardware simple.
djsfantasi
Joined Apr 11, 2010
9,237
Or 200+ relays with 4 pins...
