The input voltage is 5V for each circuit shown above. I need to find the gain of these two RLC circuits using the formula G(ω) = V_out / V_in. With this formula, I want to find the half-power frequencies of the two circuits by squaring |V_out|/|V_in| and then setting it equal to 0.5. I believe the resonance frequencies are are found by setting the reactance of of the inductor equal to that of the capacitor. This gives me f = sqrt(1/LC)/2π. Please tell me if there is a way to get it using only the gain formula.
I have made a plot of log10(f) vs. V_out/V_in in LTspice for each circuit to get an idea of what the resonance and half-power frequencies should look like.
The solid line is the magnitude of V_out/V_in while the dotted line is its phase. For the first circuit, the resonance frequency is f = 5033 Hz, and the half-power frequencies are around f = 1460 Hz and f = 17386 Hz based on this graph. For the second circuit, the resonance frequency is f = 15915 Hz, and the half-power frequency is around f = 23801 Hz.
I have tried taking the complex impedences of the inductor (jωL), the capacitor (1/jωC) and the resistor (R) then using voltage division to find the output voltage, but I am not getting the correct answers. When do this then solve for the half-power frequency, I always get 0.5=1/(2π*f^2*R^2*C^2), which does not give me the answers above. Perhaps someone can show me how to derive the gain correctly.
