Finding next state equation for UV flip flop?
Gonzalo Armbrust
Joined Jun 28, 2015
16
"A M-R flip-flop behaves as follows:
If MR = 00, the flip-flop does not change state.
If MR = 10, the flip-flop is reset; i.e. Q=0.
If MR= 11, the flip-flop changes state.The input combination
MR = 01 is not allowed.
Give the next state equation for this flip flop"
I have no idea how to solve this, could anyone provide any hints / clarifications that might help me out?
33,142
Is this a "UV" flip flop or a "M-R" flip flop?
Look at the next state equations for a JK flip flop. The idea is very similar.
Gonzalo Armbrust
Joined Jun 28, 2015
16
It's an M-R flip flop, I apologize that was a typo. I have worked out a table for the solution and I think I may have gotten it:
x's are labeled as don't cares
M | R| Q | Q(+)
x 0 0 0
------ 0 1
1 x 1 0
0 0 1 1
when Q and Q(+) are both set to zero, this satisfies the condition in which MR = 00 and when MR = 10, since Q and Q(+) does not change state, and it also "resets" to 0, so m could be either 1 or 0, or just labeled as a don't care. The case of 01 is ignored since it is not allowed. The conditions are reversed for when Q = 1 and Q(+) = 0, this means MR = 10 and also equal to 11 since the values compliment. At Q and Q(+) = 1, MR has to be equal to 00 since it does not change state...
is this correct?
33,142
I have no idea what the line in your table is that has all the hyphens.
Using TABLE tags might help.
You are talking about Q(+) as thought it is one of your inputs.
Your table doesn't cover the case where MR = 11 and Q = 0.
Gonzalo Armbrust
Joined Jun 28, 2015
16
the line with the hyphens I used to show that the case in which MR = 01 is not allowed in the problem. For a certain part, I was asked to fill out the corresponding characteristic table with the correct MR inputs, so I was given:
// MR are left blank for me to fill out
Q | Q(+) | M | R
0 | 0 | |
0 | 1 | |
1 | 0 | |
1 | 1 | |
I don't know how to use table tags.
Since I was given this specific table to fill out, I need to find the U and V inputs that satisfy these conditions, so for example M = 0 and R= 0, when Q is 1 and Q(+) is 1, since the state does not change from Q, to Q(+). Would my table be correct for these circumstances?
33,142
Q | Q(+) | M | R
0 | 0 | |
0 | 1 | |
1 | 0 | |
1 | 1 | |
What are these 'U' and 'V' inputs that you keep talking about?
