Finding intermittent faults in PIC PCB Peripherals OSHONSOFT
jjw
Joined Dec 24, 2013
823
Hi J,
I'm getting mixed up now!
The first TERM VIEW showed the odd artifacts coming from the CALLI PCB, the example I've just updated shows an example from another program to illustrate what it should look like.
Here is a screen shot of the CALLI program OSH SIMULATOR. It shows the HSEROUT and should look similar. As it's simulated, there's no DATA.
C
This screenshot is as it should be from the program in #129
camerart
Joined Feb 25, 2013
3,846
Multi embrarrasment :oops: When I popped the Radio and rewired another one in, I connected the radio to the next PIN to the TX, sorreeee.
The TERM is working now, but I need to change the program for any tests.
C
camerart
Joined Feb 25, 2013
3,846
Interesting!
When I put my hand near to the PCB, the Ghost MOSI moves up/down.
Is this capacitance? How can I correct it?
C
jjw
Joined Dec 24, 2013
823
Is it MOSI or MISO?
It looks like the signal is floating.
If the compass is in power down state, MISO could look like that.
camerart
Joined Feb 25, 2013
3,846
I've cut and pasted the later COMP calculation from a later program, into the CALLI program, where there could be errors now.
The PIC is now running 8x too slow, and not showing the SPI on the Oscillator.
This isn't important, I don't think, as the first program shows what we need for the test, so only check this one if it's felt necessary.
C
jjw
Joined Dec 24, 2013
823
It is better to hserout the data.
I think the calibration data is individual for each compass module
Hserout the angles without calbration.
camerart
Joined Feb 25, 2013
3,846
Hi J,
I just had a quick look at the #148 and can see errors, but I will have to leave some time before changing anything.
The DATA is HSEROUT (see XRAW.LB)
There is only one COMP module.
For proper working the COMP needs calibrating, or it may be out of range.
C.
jjw
Joined Dec 24, 2013
823
Hi J,
C.
I don't see any data from #148.
camerart
Joined Feb 25, 2013
3,846
Hi J,
Sorry I've just realised what you meant by "I think the calibration data is individual for each compass module " of course you're correct.
#148 is not working yet, I am just trying to get a calibrated/calculated program to work. (No DATA yet) There are errors in it, e,g, it's running 8x too slow. I'll correct it later if I can.
C
camerart
Joined Feb 25, 2013
3,846
This program was working ok, then it 'errored'
Here is a TERM READout showing intermittent firing. This also shows as before but intermittently on the SCOPE.
The MOSI is constant but the MISO at the COMP is intermittent.
I'll check the COMP set-up including the power down state, next.
C
jjw
Joined Dec 24, 2013
823
This is worse than #143
It has less than 10% sensible values.
This is wrong:
SPICSOn
compss = 0 'CHIP SELECT COMPASS ON
SPISend 0x1f '(16BIT) (FUSE) %000111111 <------
'This is for reading the fuse ROM
SPISend 0x40 '%0001000 POWER DOWN, why??
compss = 1 'CHIP SELECT COMPASS OFF
SPICSOn
Here addr has no starting value.
For i = 0 To 18 '5 'READ XYZ Xx2 Yx2 Zx2
SPISend addr
SPIReceive data
compss = 1
WaitUs 10
compss = 0
b(i) = data
addr = addr + 1
Next i
Correct to this:
addr=0x80 + i
SPISend addr
SPIReceive data
b(i) = data
Next i
camerart
Joined Feb 25, 2013
3,846
Hi J,
Hi J,
Corrected hopefully.
Moved to before MAIN
'WRITE COMPASS SETTINGS
SPICSOn
SPISend 0x40 '%0001000 POWER DOWN######WHY##############
SPICSOn
[ I'll check later ]
main: '\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
''If BAUDCON.RCIDL = 1 Then
'Toggle dataswitch 'dataswitch = 1 '0=REMOTE 1=GPS
'Toggle rled
'Toggle yled
'WaitMs 100
''Endif
SPICSOn
addr = 0x80 + i
SPISend addr
SPIReceive data
b(i) = data
Next i
SPICSOff
wIa_raw = b(0)
info_raw = b(1)
st_1_raw = b(2)
x_raw.LB = b(3) 'BYTE
x_raw.HB = b(4) 'BYTE
y_raw.LB = b(5)
y_raw.HB = b(6)
z_raw.LB = b(7)
z_raw.HB = b(8)
'Hserout "WIA ", #wIa_raw, " ", "INFO ", #info_raw, " ", "XRAW LB ", #x_raw.LB, " ", "XRAW HB ", #x_raw.HB, " ", "YRAW LB ", #y_raw.LB, " ", "YRAW HB ", #y_raw.HB, " ", "ZRAW LB ", #z_raw.LB, " ", CrLf
Hserout "XRAW LB ", #x_raw.LB, " ", "XRAW HB ", #x_raw.HB, " ", "YRAW LB ", #y_raw.LB, " ", "YRAW HB ", #y_raw.HB, " ", "ZRAW LB ", #z_raw.LB, " ", "ZRAW HB ", #z_raw.HB, CrLf
This still has 'errors'
I re-added SPICSON/OFF, as a test, but no change, I'll leave them there for now.
With COMPSS =X OUTSIDE the FOR and NEXT LOOP, the square wave is good and 3.3V, but only ZRAWHB changes.
With COMPSS = X INSIDE the FOR and NEXT LOOP, the MOSI 'raggy' slope is back but the COMP gives sensible READings, including COMPSS DEG =X
C.
camerart
Joined Feb 25, 2013
3,846
Just realised! We've been talking about the MOSI GHOST. MOSI is fine when connected to the SCOPE.
What all of the MISO images show is the MISO, which has the 'raggy' slope.
C.
jjw
Joined Dec 24, 2013
823
Hi J,
Hi J,
SPICSOn
SPICSOn
'Toggle rled
'Toggle yled
'WaitMs 100
''Endif
SPICSOn
addr = 0x80 + i
SPISend addr
SPIReceive data
b(i) = data
Next i
SPICSOff
wIa_raw = b(0)
info_raw = b(1)
st_1_raw = b(2)
y_raw.LB = b(5)
y_raw.HB = b(6)
z_raw.LB = b(7)
z_raw.HB = b(8)
C.
You have not set the measurement mode.
