Finding intermittent faults in PIC PCB Peripherals OSHONSOFT
camerart
Joined Feb 25, 2013
3,853
compss = 0 'CHIP SELECT COMPASS ON
'For i = 0 To 18 '5 'READ XYZ Xx2 Yx2 Zx2
'SPISend addr
'SPIReceive data
'b(i) = data
'addr = addr + i
'Next i
'compss = 1 'CHIP SELECT COMPASS OFF
This does not work at all.
Find out why by going through the for next loop and calculating addr with each value of i.
Hi J,
Both #18 sections work as good as each other. Both error 25% of the time, but if no error at start-up, then both seem reliable.
I guess that with the [ addr = addr + i ] after SPISEND, then it gets a READing beforethe start of the 1 to 18 LOOP, so givig an extra READ at the end?
EDIT: From the tests I've tried, I'm pretty sure the problem is at the PIC end, as the SPI signals are arriving.
NOTE: Normally I'm programming the PIC using a Pickit3, that has a MCLR PIN, and needs the PIC to be powered up before programming. If I'm not programming, but testing, and try a test, without the Pickit3 attached, then I get error with all the last tries. However, as soon as it was attached and powered, then no error. So perhaps it is a PIC initiation problem
EDIT EDIT: I've just checked the PCB, and noticed that there are no capacitors near the PIC power PINS, which is suggested. I'll add some.
jjw
Joined Dec 24, 2013
823
addr=addr+i
'SPISend addr
'SPIReceive data
'b(i) = data
'Next i
Assume that addr is correct 0x80 when the loop starts
i=0 addr to read from =0x80 is correct
i=1 addr =0x81 is correct
i=2 addr =0x83 not correct, skipped 0x82
i=3 addr=0x86 not correct, skipped 0x84, 00x85
etc.
Maybe you get some non zero values and angle is different from 306 but is still wrong.
camerart
Joined Feb 25, 2013
3,853
addr=addr+i
'SPISend addr
'SPIReceive data
'b(i) = data
'Next i
etc.
Hi J,
Of course! ADDR is incrementing and plussing [ i ]
SPISend addr
SPIReceive data
b(i) = data
addr = addr + 1
Next i
addr = 0x80
Is this correct?
EDIT: addr = 0x80
C
jjw
Joined Dec 24, 2013
823
It is correct, but this is simpler
addr=0x80+i
Spisend addr
etc
You could make a test reading xyz one by one without looping and printing them.
Spisend 0x83
Spireceive data
X.lb=data
Spisend 0x84
Spireceive data
X.hb=data
Same for y and z
You could use the analyzer to check the data coming from the compass.
jjw
Joined Dec 24, 2013
823
Hi J,
SPISend addr
SPIReceive data
b(i) = data
addr = addr + 1
Next i
addr = 0x80
Is this correct?
EDIT: addr = 0x80
C
addr=0x80 has to be before the loop
camerart
Joined Feb 25, 2013
3,853
Hi J,
Up to now there was an [ addr = 0x80 ] before the MAIN LOOP, I'll remove it for clarity, and use you CODE.
First/
Connected analyser with recent program with this section (Bear in mind that we don't use the [ i ] anymore, but this is just to show)
compss = 0 '* * * * * moved before For Next loop * * * *
For i = 0 To 18
addr = 0x80 + i
SPISend addr
SPIReceive data
b(i) = data
Next i
compss = 1 '* * * * moved after the the loop * * * *
Here are the Terminal and analyser READings
C.
camerart
Joined Feb 25, 2013
3,853
Hi J,
Second test, with individual READs
compss = 0
SPISend 0x83
SPIReceive data
hxl = data
Hserout "HXL ", #hxl, CrLf
'compss = 1
'compss = 0
SPISend 0x84
SPIReceive data
hxh = data
Hserout "HXH ", #hxh, CrLf
'compss = 1
'compss = 0
SPISend 0x85
SPIReceive data
hxl = data
Hserout "HYL ", #hyl, CrLf
'compss = 1
'compss = 0
SPISend 0x86
SPIReceive data
hxl = data
Hserout "HYH ", #hyh, CrLf
'compss = 1
'compss = 0
SPISend 0x87
SPIReceive data
hxl = data
Hserout "HZL ", #hzl, CrLf
'compss = 1
'compss = 0
SPISend 0x88
SPIReceive data
hxl = data
Hserout "HZH ", #hzh, CrLf
compss = 1
TERM and ANALYSER
C
camerart
Joined Feb 25, 2013
3,853
Hi J,
Third test/
addr = 0x80 '!!!!!!!!!!!!!!!!!
SPISend addr
SPIReceive data
b(i) = data
addr = addr + 1
Next i
Term and Analysis.
C
jjw
Joined Dec 24, 2013
823
Hi J,
compss = 0
SPISend 0x83
SPIReceive data
hxl = data
'compss = 1
'compss = 0
SPISend 0x84
SPIReceive data
hxh = data
'compss = 1
'compss = 0
SPISend 0x85
SPIReceive data
hxl = data
'compss = 1
'compss = 0
SPISend 0x86
SPIReceive data
hxl = data
'compss = 1
'compss = 0
SPISend 0x87
SPIReceive data
hxl = data
'compss = 1
'compss = 0
SPISend 0x88
SPIReceive data
hxl = data
compss = 1
TERM and ANALYSER
C
Is the angle sensible?
Could you make individual reads and change the compass orientation after each xyz for example N,E,S,W
camerart
Joined Feb 25, 2013
3,853
Hi J,
I tried individual READs, but I got worse results. I also tried other ideas, but still no good.
We've spent a long time on this, so I think I had better go back and prove the COMP/PCBs and re-calibrate etc, before going farther along this track.
In the meantime, I'll go back to the MAIN thread, and try to finish the MAIN program, without the COMP for now.
Thanks, again for your patience.
C.
camerart
Joined Feb 25, 2013
3,853
I'm looking for likely things that would give intermittent faults, i,e, Components, soldering, programming etc.
I've got 5xCompass modules, and 3x PCBs.
We've altered the program many times.
I've searched online, and seen mentions of PULL RESISTORS, which I'll try, but having checked with a DATA Analyser, and Oscillator, doubt it's that.
I've just spotted this:
The SCK is oscillating opposite to the D/S recommendations, could this cause intermittent faults? (After past comments, I hope the detail can be seen)
NOTE: The top analysis is working, the bottom is not working. I've tried adding the DIS/ENABLEs in between the READS, but no difference.
EDIT: Here's the SPI clock modes from the 18F4620 D/S
EDIT EDIT: I'm checking this previous explanation: https://forum.allaboutcircuits.com/...wspi-in-oshonsoft.156175/page-10#post-1411674 e,g, #193
C
camerart
Joined Feb 25, 2013
3,853
I just tried to change SSPSTAT and SPCON1 to the best of my abilities, but it still errors :(
I'm happy to test any other settings
C
jjw
Joined Dec 24, 2013
823
1) No.
2) What do you mean by opposite to recommendations?
Look at the Oshonsoft Basic manual. There are some settings for the Spi clock.
camerart
Joined Feb 25, 2013
3,853
1) No.
Hi J,
I have collected a lot of help files for Oshonsoft over the years, including PIC Simulator IDE BASIC Compiler Reference Manual , much of it looks redundant, so needs clearing out. I don't think I've got the actual Oshonsoft Basic manual. I'll download it and check your comment.
C
