Finding formula for this circuit...!!
Himanshoo
Joined Apr 3, 2015
265
Hey friends please help me on this..
q.1 what will be the gain expression of this circuit..?
q.2 what will be the equivalent resistance between point x and ground..with formula..??
q.3 what effect will be on gain if the value of Cfb1 is increased??
Thanks!!
Himanshoo
Joined Apr 3, 2015
265
Since this is a 'Homework help' forum, not a 'Homework done for you' one, show us your efforts so far.
yeah..the gain expression for a common emitter circuit is
(Rc//RL)/re'
where re' is the ac resistance of base emitter junction and its value is 26mv/Ie...
now the thing which I am asking first is that how the involvement of Cfb1 will modify the gain expression...??
btw nice humour:)
MrAl
Joined Jun 17, 2014
13,787
Thanks!!
This circuit/question looks like it may be set up wrong or something is missing.
For example, with very low input voltage we have essentially a constant current source in series with a capacitor. Eventually the cap charges up and then there's nothing to stop it from charging more. Using pure theory with no component limits, the cap would charge up to an infinite voltage level.
So something else has to be specified, such as the leakage of the transistor, min input, or something else to make this a real solvable problem.
Jony130
Joined Feb 17, 2009
5,599
Also I don't see any biasing network. So what is the operation point ?
Also try find a gain expression for this circuit
Himanshoo
Joined Apr 3, 2015
265
Hi jony...
Actually these days I am focussing on Miller Compensation aka pole splitting..and Ive found a magnificent and simplest explanation ever on it unlike regular textbooks..here the link below...
http://stephan.win31.de/music.htm#polesplit
So actually now its not a Homework problem...must be redirected...to other section..
Jony130
Joined Feb 17, 2009
5,599
bootstrap action of Cfb1
But this time the gain is negative so we do not "bootstrap" anything. And this is why we have a "Miller capacitor" this time.
The gain expression of this circuit should be..
Av = {-β(Rc2//Rc1)/αRs} / 1+β(Rc2//Rc1)/αRf
Am I right??
The voltage gain without RF resistor is equal to
Av1 = - Rc2/re' * alpha if we driven our amplifier from the ideal voltage source (Rs = 0Ω).
And now if we add RF into the circuit the voltage gain will almost remains unchanged if Rc2 << RF.
And if we include Rs and using a miller effect we have
Avf ≈ - Rin*(Rs+Rin) * (Rc2||RF)/re' * alpha
where
alpha = β/(β+1)
Rin ≈ RF/(1-Av1)||(β+1)*re'
Notice the "miller effect" on RF.
Himanshoo
Joined Apr 3, 2015
265
yeah the feedback resistance appears to be decreased by (1-Av1) times due to miller effect..
So what effect will it make in the expression if Rf will be replaced by a capacitor..however text says that for a common emitter circuit miller effect acts as a degenerative feedback decreasing the voltage gain...
Jony130
Joined Feb 17, 2009
5,599
But for Rs = 0Ω and RF>>Rc2 the gain will not change much. But with Rs > 0Ω and together with RF/(1 - Av) (decreased by Miller effect) form a voltage divider and this will decrease the voltage gain.
Well, at first glance we can treat Cf as a frequency dependent resistor (Xc). And resistance of this resistor decreases with frequency.
For DC the gain is Rc/re' but as signal frequency increasing the gain of a amplifier start to drop at rate 20dB per decade (the roll-off will start at F ≈ 0.16/(1+Av*Cf*Rs)), because now this amp start to behave just like a poor's man integrator.
Himanshoo
Joined Apr 3, 2015
265
But why you want to do such a thing ?
Because I am thinking that if Cfb1 increases gain decreases because Xc decreases and if Xc decreases total impedance decreases ….
here what is important for me to know is..in calculating the impedance between point x and ground..does it involves only Rout1 and Xc (reactance of Cfb1)..or any other value like re’ or resistance between collector and emitter terminal…etc.
Jony130
Joined Feb 17, 2009
5,599
Cfb capacitor is seen at the output as a capacitor equal to (1 + 1/Av)*Cfb.
But the author was talking about this circuit
And, as I said earlier the VAS stage for the DC and low frequency signals behaves like an ordinary common emitter amplifier with gain -Rc/re. But as signal frequency increases the gain of a amplifier start to drop at rate -20dB per decade (the roll-off will start at Fc ≈ 0.16/((1+Av)*Cf*Rs||(β+1)*re) open loop). Because Cfb capacitor controls the high frequency gain of the VAS (Cfb forms a shunt feedback loop around the VAS.) And this means that for F > Fc this stage becomes an Miller integrator where the output voltage is the integral of the input current.
http://www.ecircuitcenter.com/Circuits_Audio_Amp/Miller_Integrator/Miller_Integrator.htm
Himanshoo
Joined Apr 3, 2015
265
Sorry for delayed response...
Ok now talking about the shift of second pole to a higher frequency..the text says..
The text means that the second pole occurs due to an RC Filter caused by Rout1 and Cin2 ....
now what I think is that if
if Rout1 decreases then Cin2 increases ..if Cin2 increases then its Xc decreases..and if Xc decreases ..more signal from the previous stage will pass on to the ground thus robbing of the second stage with sufficient input signal..which causes the output of second stage to roll down early for low frequencies as well...so where does the second pole seems to shift up in frequency according to text..
