You are so close. Where you have erred is while the voltage across R3 and R4 is the same it is not 24V. Notice that the parallel combination of R1 and R2 forms a resistor voltage divider with the parallel combination of R3 and R4 and therefore the voltage across the resistors is not the full 24V.JoeJester, Thank you so much for taking time to explain. I see the mistake, but from other hand looking at the circuit (if it is drawn correctly) isn't R3&R4 connected to 24V, from that: Voltage in parallel is the same and to find current through I4=V4/R4
hgmjr
