Not finding any information about input current in the datasheet
lemongrass
Joined Jul 11, 2023
9
Hi! I am new to electronics, please don't judge my misknowledge.
I am using a power multiplexer (TPS2113A) to switch between two power sources (5V 1A cable and usb VBUS), the output of the multiplexer gives 5V and up to 1.25A. This output will then go to a linear voltage regulator (LD1117#33) to drop it to 3.3V but here is the problem, I am not finding any information about the input current of the voltage regulator (if it makes sense?!). I only found the output current that can go up to 800mA. Can you please tell me if the input current makes sense and if yes, should I change the regulator or add a resistance to drop the current? thank you!Screenshot 2023-07-11 103359.png
lemongrass
Joined Jul 11, 2023
9
hi LG,
Welcome to AAC,
The Input current will only be few mAmps above the current you are actually supplying to 3.3v Load.
E
Thank you for replying, but I did not understand, is it acceptable to give the voltage regulator 1.25A ? if yes, how much is it going to give in the output (the datasheet says that the maximum output current is 800mA
ericgibbs
Joined Jan 29, 2010
21,583
Consider your required 3.3v load current was say 500mA.
The Input current to LD1117 would be approx 510mA.
If your 3.3V load required only 100mA, then the Input current would be approx 110mA.
You don't set the input current to the LD1117.
Do you follow OK.
E
Update: post the circuit you are powering with the 3.3V
Alec_t
Joined Sep 17, 2013
15,156
If you try drawing more than the rated maximum 800mA from the regulator output it will go into self-protect mode and limit the current as per the datasheet.
sarahMCML
Joined May 11, 2019
703
I am using a power multiplexer (TPS2113A) to switch between two power sources (5V 1A cable and usb VBUS), the output of the multiplexer gives 5V and up to 1.25A. This output will then go to a linear voltage regulator (LD1117#33) to drop it to 3.3V but here is the problem, I am not finding any information about the input current of the voltage regulator (if it makes sense?!). I only found the output current that can go up to 800mA. Can you please tell me if the input current makes sense and if yes, should I change the regulator or add a resistance to drop the current? thank you!View attachment 298110
Why do you have resistor R15 in your circuit. It is only shown in the datasheet as a test load, and isn't needed in your application. It's wasting about 100 mA of current unnecessarily!
DickCappels
Joined Aug 21, 2008
10,661
Though what delivers power to your regulator may be capable of supplying 2.5 amps, the regulator will only draw the current required by its load. The "2.5 amps" is the available current, not necessarily what will be supplied.
