Find the voltage and current in the following circuit.
shteii01
Joined Feb 19, 2010
4,644
I was taught that when using Mesh-Current Method, all the mesh currents should be rotating in the same direction. This simplifies the analysis.
WBahn
Joined Mar 31, 2012
33,327
You claim to have solved for i(t) after doing just one loop equation. What happened to i2? In the next loop equation you claim that i2 = 0. What is that claim based on?
MrAl
Joined Jun 17, 2014
13,874
Hi again,
Yeah i was wondering that too :)
My advice for him based on his replies and attempts would be to try to solve a SINGLE loop circuit first, then move on to a two loop circuit. Get that right first, then move on to a more complicated circuit.
NOTE to the OP:
Typically for a two loop circuit you would have two currents to solve for i1 and i2, so you would have two equations, and you would solve those two equations simultaneously for i1 and i2 and then go from there.
