Find Efficiency of a Buck Converter
38,827
Below is the LTspice simulation of a simple buck converter that goes from 5V to 500mV.
Note that the average output current is about 133mA while the average diode current is about 97mA.
ci139
Joined Jul 11, 2016
2,033
some formulas related #4 topology . . .
. . . it is still complicated - but possible to match required duty for .5V , 50A by last 3 formulas @ fig.2
as it turns out "0"-use - it still goes to that "Diode - dilemma" as in #18 ←
or then not --
-- because of the erroneous definition of duty in #18
I am just doing some reading on power electronics and I came across this question. They state the answer, which is 0.55. What I can't figure out is how they got the answer. The questions is:
"A dc-dc converter has an input voltage of Vg=5V, and it supplies a computer processor with V=0.5V at 50A (25 W). The converter is a buck converter, and it uses a diode having a forward voltage drop of 0.5V. All losses other than the diode conduction loss are negligible. Estimate the efficiency of this converter"
Efficiency is given by PowerOut/PowerIn. The Power out is 25W, information is given. I apologize if this seems vague but this is essentially all the information I have. I am assuming the Diode is acting like a parallel switch to the output and a MOSFET in series with the voltage source Vg. If someone can help me understand the process of getting the answer. I did a quick search on here but with no luck. Thank you in advance.
