Find and correct the mistakes: Synchronous N.E.T. JK-FF mod-15 up counter
ssddssdd
Joined Feb 29, 2020
We are given this counter diagram:
And we must locate the mistakes and correct them, to make sure it's a synchronous mod-15 counter.
Now, from what I've tried it should look like this:
So when it reads 1110 (14), it resets the counter to 0000.
Is my answer correct?
dl324
Joined Mar 30, 2015
18,523
Welcome to AAC!
Your answer in incorrect.
Do you have this circuit in a simulator? If so, what does it show happening during the transition from 13 to 14?
ssddssdd
Joined Feb 29, 2020
Welcome to AAC!
Thank you.
No I don't, it's supposed to be hand-drawn using Karnaugh etc. and I tried solving it as is.
WBahn
Joined Mar 31, 2012
33,349
For starters, your proposed solution is not a synchronous counter because you are using the asynchronous resets as part of the normal operation. Note that even the original circuit did not use (or even have) the resets.
